Activity Forums Zaxwerks Camera Orbit
  • Camera Orbit
    Posted by Robert Hoffman on April 8, 2011 at 8:48 pm
    I have created some moving 3d objects in invigorator. These objects are in individual sets because I need to animate their movement independently. I would like then to orbit either the invigorator camera or the AE camera around them, however when I try the camera does not orbit 3d center. How do I reset the camera to orbit 3d center?
    Rob
    Stephen Stavar replied 15 years, 4 months ago 3 Members · 2 Replies
  • Edward Wu
    April 12, 2011 at 4:12 pm
    Hi Robert,
    Be sure the objects you’ve created are at the center of the 3D Scene/world. To do this, select your objects, and select the “Reset Tweaks” command, or use the “Move to Center” command. This will move your objects to the center, and you will be able to use either the After Effects camera, or the Invigorator camera to orbit around your objects.
    Best,
    Edward
  • Stephen Stavar
    April 19, 2011 at 6:56 pm
    Let’s say you had a group of objects. Is there a way for the objects to always face the camera while the camera moves around the group of objects?
    Chewie
