Activity Forums Adobe After Effects Camera only rotates in two dimensions
  • Camera only rotates in two dimensions
    Posted by Nicholas Shera on December 25, 2008 at 3:29 am
    I have a camera set up in a 3D environment. I have Point of Interest turned off (I find its motion too unpredictable). So instead I’ve just been using the camera’s position and rotation co-ordinates to get it to aim at whatever I want.
    However I just discovered a really annoying problem where changing the X rotation values will cause the camera to rotate around the Z-axis, and not the X-axis as it should. In other words, I cannot get the camera to rotate around the X-axis, no matter what I do! I have not touched the orientation values at all. I have set up a new camera and the problem goes away. But I shouldn’t have to do this. Has anyone else experienced this problem and do you know anything I can do to solve it?
    I’m running AE CS3 with a Mac Pro (8-core) and 15 GB of RAM.
    Nicholas Shera replied 17 years, 8 months ago 2 Members · 2 Replies
  • Mike Park
    December 26, 2008 at 12:45 am
    try parenting the camera to a 3d null object and animating the null instead. That should clear up the problem
  • Nicholas Shera
    December 26, 2008 at 12:54 am
    Thanks for the tip. I was thinking that maybe using a null object might be the way to go.
