Activity Forums Maxon Cinema 4D camera moves
  • camera moves
    Posted by Hamid Rohi-bilverdy on May 10, 2010 at 8:15 pm
    hi. I created a text and some lights and a camera movement. I rendered it out as a after effect comp and importet it to ae. In ae when i scrub the timeline the camera moves as i animated it but the text stays center. The camera was supose to animate around it.what am i missing?
    Hamid Rohi-bilverdy replied 16 years, 4 months ago 2 Members · 4 Replies
  • Adam Trachtenberg
    May 10, 2010 at 8:22 pm
    AE does not support 3D objects except for cameras, solids, and nulls, so you can’t import 3D text. Camera import is for matching 3D layers that you might want to add in AE.
  • Hamid Rohi-bilverdy
    May 10, 2010 at 8:56 pm
    so can i import the text as a still, and then use the camera data to rotate around it? Or what is the approch when i want to make the camera to rotate around a text i create in cinema4d?
  • Adam Trachtenberg
    May 10, 2010 at 9:03 pm
    The approach would be to animate the camera move in Cinema and render it out there. You could render out various passes and then send it to AE if you wanted to adjust colors, reflections, etc., or if you wanted to add elements in AE.
    May 11, 2010 at 4:49 pm
    What is the difference between Target camera and the normal camera?
    I used camera and now i got my animation with the text, but the tutorial i followed on cg + was with the target cam!!!
