Activity › Forums › Adobe After Effects Expressions › Camera movement with Sound Keys
  • Camera movement with Sound Keys
    Posted by Neal Brewer on October 13, 2016 at 11:04 pm
    I’m trying to move my camera along the Z axis at a constant pace, but I want it to speed up speed with the bass from Sound Keys. I found that using integrate instead of falloff in Sound Keys worked to an extent, but the speedup ends too abruptly without a falloff. I imagine this can be solved with expressions, but I don’t know how.
    I.E. I want a base speed + speed from Sound Keys frames.
    Any help would be much appreciated. <3
    Neal Brewer replied 9 years, 11 months ago 2 Members · 6 Replies
  • Dan Ebberts
    October 13, 2016 at 11:54 pm
    Something like this, probably:
    spd = 100;
    zOffset = spd*time + thisComp.layer(“Sound Keys”).effect(“Sound Keys”)(“Output 1”);
    value + [0,0,zOffset]
    Dan
  • Neal Brewer
    October 14, 2016 at 12:10 am
    I was using a similar expression, but it only works when using “Integrate” falloff in soundkeys, even though I want the ramping down effect of Linear or Exponential falloffs. Without Integrate, the expression always moves the camera in reverse after the sound stops or drops off for a moment.
    Thank you for the reply, by the way! I’m hoping we can solve this issue.
  • Neal Brewer
    October 14, 2016 at 12:11 am
    Though, I would like to add that I have the dimensions all separated, so this is the expression I’m using. I don’t think that would be the cause of the issue though.
    spd = 100;
    z = spd*time + thisComp.layer(“Sound Keys”).effect(“Sound Keys”)(“Output 1”);
    value + z
  • Dan Ebberts
    October 14, 2016 at 12:24 am
    I was assuming you were using “None (integrate)”. It’s a lot trickier if you have to devise your own integrate/easing function.
    Dan
  • Neal Brewer
    October 14, 2016 at 12:42 am
    Damn..
    I’ll use integrate if we can find a way to ease it. Possibly setting all the keyframes from Soundkeys output to ease out?
  • Neal Brewer
    October 14, 2016 at 1:02 am
    I feel like setting the soundkey keyframes to ease out helped a little bit (Might be convincing myself though?), but I’d still like it to falloff over a longer period of time. Hmn.. I might just try to hide the sharp slowdown with blurs and glitch effects, if we can’t find a way. Of course though, I thank you for the help. ?
