Activity Forums Maxon Cinema 4D Camera movement problem attached with spline in Cinema4D
  • Camera movement problem attached with spline in Cinema4D
    Posted by Vipati Hitesh on March 24, 2012 at 4:23 am
    Hi All,
    I am new to C4D. I have C4D R11.5. I have attached my camera
    with spline though it is not moving with spline and moving in wrong
    direction. OK let me give you some more detail.Actually I want to
    make my camera move with spline. To do this I have followed below
    steps :
    1. I created a cylinder.
    2. Mark hight segments : 50
    3. Select one raw of edges and convert that edges to spline.
    4. I attached camera with that spline
    5. I used bend deformer on cylinder.
    After that when I tried to move camera with (bended) spline but
    it didn’t move with that and it is moving in the direction of
    spline’s original shape (before I used bend deformer). Please see
    attached image and you will understand what I want to say. Please
    tell me how can I move camera in right direction.
    Thank you,
    V!pati
    Tim Shetz replied 14 years, 5 months ago 3 Members · 2 Replies
  • Adam Trachtenberg
    March 25, 2012 at 5:27 pm
    If you have MoGraph … and if there was a MoSpline object in that version … that’s what I would use. Basically the mospline traces your deformed spline, and you would align the camera to the mospline instead of the original.
    Another method, if you have MoGraph, would be to use a matrix object to clone some particles on the points you used to create the spline and then use the mograph tracer to trace a spline between the particles.
  • Tim Shetz
    March 25, 2012 at 8:08 pm
    Could you simplify by creating a spline that curves the way you want it to (drawn using bezier spline tool), use a sweep nurb (with a circle) to create the tube and then use the same spline again to animate your camera?
    __________
    Tim Shetz
    c4dtraining.com
