Activity Forums Adobe After Effects Camera Movement: Keeping camera still and make everything else move (what to do with rotating arm?)
  • Camera Movement: Keeping camera still and make everything else move (what to do with rotating arm?)
    Posted by Wouter Dijkstra on May 5, 2019 at 1:00 pm
    The arm gives me trouble. I want someone filming himself in the mirror. The arm should move with the camera, but shouldn’t move like all the other objects in the room. In the video I try to show my problem. The end shows the result I am looking for.
    https://f1.creativecow.net/13321/13321‘>13321_cameramovement.mp4.zip
    I am looking for a way to first move the Arm/Camera (with keyframes) and than with expressions make it “still” again.
    Thanks guys!
    Wouter Dijkstra replied 7 years, 4 months ago 2 Members · 3 Replies
  • Kalleheikki Kannisto
    May 6, 2019 at 6:36 am
    I would not go the complicated way of first moving the camera and then reversing everything. Just move everything but the camera. Link the arm to the non-moving camera and the bear to it, then the position of the background objects to the bear. Done.
    Senior Graphic Designer
    May 6, 2019 at 6:38 am
    To keep something parented from rotating, subtract the parent’s rotation from the child object’s rotation.
  • Wouter Dijkstra
    May 6, 2019 at 1:43 pm
    Thank you! I go see if it works ☺
    I wanted to move the camera first because he is standing in a mirror and it was animated more “naturally”. I appreciate helping me out!
