Activity Forums Maxon Cinema 4D camera movement does not render – HELP!
  • camera movement does not render – HELP!
    Posted by Ste Kerouac on June 16, 2006 at 9:38 pm
    I am a beginner having a problem with C4D 9.1. I have a camera movement set up but it will not render. I DO have ‘use as render view’ enabled in the viewport which has the camera set as its camera>scene camera. The movement looks fine in this window. If I set my render settings to begin at frame 30 or 40 say, it will render all 90 frames as frame 30 or 40… eg. it gets the first rendered frame ‘right’ in terms of the camera movement, but then renders all the subsequent frames exactly the same as that one. What am I doing wrong? I’m an AE user who has picked up C4D basics in a day and was really pleased but this one thing has totally stumped me, its so frustrating cos otherwise I’ve got exactly what I need.
    Lennart Wåhlin replied 20 years, 3 months ago 2 Members · 1 Reply
  • Lennart Wåhlin
    June 16, 2006 at 11:08 pm
    Check RenderSettings (Cntr+B) ->Output ->Frame. It is probably saying “Current Frame”.
    Set your prefered range there.
    Cheers
    Lennart
