Activity Forums Adobe After Effects Camera movement control…
  • Camera movement control…
    Posted by Lex Park on August 31, 2007 at 7:29 pm
    Hey Cows,
    I need some help… I’m trying to do an animation where at the start, the camera begins moving forward while following a winding path (a red line, for now). While it winds around in this forward-moving manner (like driving), images, text, and other content pass by.
    I cannot for the life of me figure out how to follow this line with the camera without painstakingly trying to key the movements using a Null layer to control the camera. Is there an easier way to do this?
    Any help will be greatly appreciated, as always.
    – The Foonshoe
    Lex Park replied 19 years ago 3 Members · 5 Replies
  • Lex Park
    August 31, 2007 at 7:37 pm
    Oh, I created the line in Illustrator so I could zoom right in on it without losing crispness (with the continually rasterize setting AE).
    I drew up the curvy line, then in AE, converted that layer to 3D and set the X Orientation to 273
  • Josh Kirschenbaum
    August 31, 2007 at 9:32 pm
    You can use illustrator paths as “paths” for animation – just highlight the Z position of the camera and paste the path from illustrator – it will add keyframes to follow the path. I use this technique all the time to create circular path animations without having to use nulls…
  • Mike Clasby
    August 31, 2007 at 10:28 pm
    Yep… here’s a walk through and a few other tips:
    Expressing the Camera: Animating Along a Path
    https://library.creativecow.net/articles/gerard_rick/AEWeekly1.php
    And a second that uses expressions to look ahead:
    https://library.creativecow.net/articles/gerard_rick/AEWeekly2.php
  • Lex Park
    September 7, 2007 at 7:38 pm
    Incredibly helpful! Thanks!
  • Lex Park
    September 7, 2007 at 7:39 pm
    Thanks a ton! That tutorial gave me exactly the info I needed to help clear things up. Thanks again!
