Activity Forums Cinematography Camera movement
  • Camera movement
    Posted by Mira Mel on June 5, 2025 at 7:37 pm
    Hello! Could you tell what kind of camera movement or equipment was used for this shot? I’m curious whether it was achieved with a gimbal, a drone, or a specific rig or technique?
    I shoot with a gimbal on my phone, but I can’t achieve that semicircle or arc effect — I don’t know how to explain it.
    https://youtu.be/pTuZQcOaxwM
    Mira Mel replied 1 year, 2 months ago 2 Members · 2 Replies
    June 5, 2025 at 11:18 pm
    Hey Mira,
    There are so many ways that you can recreate that shoot.
    You could use your phone and the gimbal that you have, but you would need to “pan/tilt” the phone whilst moving it.
    As your example is partly in a tight space, and it is out of Germany, I would lean towards using a camera slider.
    Using a mounted SLR (Canon/Panasonic/Sony/Nikon) or small Blackmagic/Canon/Sony video camera with the right lense (wide/macro, but not fish-eye, although that can be fixed in post).
    Use a Tripod fluid head + plan out your set of shots.
    If you look carefully, you will notice on several shots that the camera moves (tracks) in a forward direction, whilst the camera (imaging part, the lens) is panning in the opposite direction.
    You also need to take note of the composition of the shot, and distance to the subject.
    For extra control, you could use a motorised slider with a controlled panhead, either real-time or time-lapse.
    Hope that this help you get closer to your desired result.
  • Mira Mel
    June 23, 2025 at 11:43 pm
    thanks so much
