Activity Forums Apple Motion Camera movement
  • Camera movement
    Posted by Schlanger Tamás on October 2, 2012 at 10:59 pm
    Does anybody know how to record in keyframe editor a 180º camera movement what I like in a perspective view creating with ‘Adjust 3d transform’ tool?
    It is easy to create using this tool but hard to program because for this you need to change frame by frame all the three rotation controller (x,y,z) as a special curve.
    I tried to record it realtime using that ‘Adjust 3d transform’ tool but it is not a professional and an easy editable solution..
    Tamas
    Mark Spencer replied 13 years, 11 months ago 2 Members · 1 Reply
  • Mark Spencer
    October 2, 2012 at 11:08 pm
    You really want to use the Sweep behavior for this (Behaviors > Camera) – it perfectly rotates the camera around an object placed at its focal plane on any axis you choose. If you want to animate more than one axis, just add more Sweep behaviors.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
