Activity › Forums › Adobe After Effects Expressions › Camera motion paths are not visible
  • Steve Roberts
    October 9, 2006 at 5:58 pm
    Check the “view options” flyout button at the top right of the comp window.
  • Riccardo Sinti
    October 9, 2006 at 6:46 pm
    All the view option check boxes are checked and hiding is turned off.
    This seems like a bug to me.
    Thank You
  • Riccardo Sinti
    October 9, 2006 at 9:20 pm
    Oh yes I do.
    Motion Paths are visible for all other objects, but not the camera, unless I create a new camera, which of course takes over in the active camera viewer. I see the motion paths of the camera if I look at, say, front view, but not in Camera 1 view.
    I’ve never seen this before.
    Thank You
  • Riccardo Sinti
    October 9, 2006 at 9:39 pm
    And furthermore I don’t get any axis handles as well, and this seems to be a problem at all my AE stations.
    Thank You
  • Steve Roberts
    October 10, 2006 at 12:39 am
    Hmm … so you can’t see the motion paths of the camera through which you are viewing?
    So if you’re looking through Camera 1, you can’t see its own motion path?
    I think that’s normal.
    Nevertheless, if that’s the case, make a new camera and either parent it to camera 1 or pickwhip its position/rotation to camera 1 using expressions. So you will look through camera 2 and see camera 1’s motion path, and still be seeing things from camera 1’s vantage point.
