Activity Forums Adobe After Effects Camera motion path keyframe issues
  • Camera motion path keyframe issues
    Posted by James Mablin on June 3, 2009 at 1:22 am
    Hi folks. New to the forum and hoping someone could help me! The comp I have is set up with a number of 3D layers that stay in their original position (dotted around the 3D space) throughout. The idea is the camera moves around, and stops when it gets to each layer for a few seconds and then moves on to the next. I am desperately trying to complete each camera move using only 2 keyframes, a starting position and an ending position. I am then using the convert vertex tool on the camera motion path when I want the camera to do anything other than go in a straight line from point A to point B.
    When it gets to point B I am adding another position and POI keyframe 3 seconds on in the timeline which is identical to the point B keyframes. From there, the camera goes on to point C, waits 3 seconds, on to point D and so on.
    The problem I am having is in the 3 seconds when the camera is meant to be stationary, it moves around seemingly randomly and yet ends up in the same spot (where the copied keyframe is placed). There are no other keyframes within this 3 second pause, and I cannot for the life of me figure out what is possessing my camera! It seems to make no difference what kind of keyframe I use.
    Confused and stumped! Hope someone has a more logical explanation than mine right now which is that there are gremlins in my machine!
    James
    James Mablin replied 17 years, 3 months ago 3 Members · 4 Replies
  • Simon Bonner
    June 3, 2009 at 3:27 am
  • James Mablin
    June 3, 2009 at 3:38 am
    Thanks Simon 🙂
  • Todd Kopriva
    June 3, 2009 at 4:26 am
    What you’re seeing is sometimes referred to as “boomerang motion”. It comes from the spatial interpolation for keyframes being bezier when they would be more appropriately linear for this purpose.
    See the “Controlloing change with interpolation” section of After Effects Help for a full explanation and some tips on correcting this. There are a couple of links on that page back to some videos here on the COW by Aharon Rabinowitz that do a good job of showing this, too.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • James Mablin
    June 3, 2009 at 8:14 am
    Thanks Todd. I actually found those tutorials, and they really helped.
