Activity Forums Adobe After Effects Camera Motion Not Producing Motion Blur
  • Camera Motion Not Producing Motion Blur
    Posted by Matt Reyer on March 24, 2010 at 3:35 am
    I have a composition with 3D objects and a camera. Motion blur is turned on for everything, and in the composition switch. When I move any objects in X, Y, or Z space, motion blur is created correctly. However, when I move the camera (it is very quickly, so motion blur should be created), no motion blur is created. How do I make it have motion blur just like everything else?
    Thanks in advance!
    Matt
    Darby Edelen replied 16 years, 5 months ago 2 Members · 3 Replies
  • Darby Edelen
    March 25, 2010 at 3:43 am
    I’m at a loss.
    Something is obviously wrong, but I can’t imagine what it might be. So I’m going to blame the usual culprit: disable OpenGL if you have it enabled.
    You’re still not seeing motion blur from camera motion when you render? Can you post a render so we can see what the problem looks like? Can you post some screenshots of your timeline?
    Darby Edelen
  • Matt Reyer
    March 25, 2010 at 10:02 pm
    Ah! You’re smart! Turning off OpenGL solved it.
    I assume OpenGL causes problems like this often, or is it just with motion blur?
  • Darby Edelen
    March 25, 2010 at 10:41 pm
    The OpenGL renderer does not support all of the features that the After Effects software renderer does.
    Darby Edelen
