Activity › Forums › Adobe After Effects › Camera looks like it’s in a dissolve mode
  • Camera looks like it’s in a dissolve mode
    Posted by Lisa Inserra on March 13, 2013 at 4:39 pm
    I’ve cleared my preferences and am back to default, but every time I use a camera my graphics look like they’re in a dissolve mode. No fast previews on. Zoom quality set to accurate in previews pref. Comp looks the same in 8, 16 and 32 bit. Disable camera – no dissolve.
    Any suggestions?
    Lisa Inserra replied 13 years, 6 months ago 4 Members · 11 Replies
  • 11 Replies
  • Vishesh Arora
    March 13, 2013 at 5:01 pm
    Lisa
    If you could upload a screenshot of comp, It would help to solve the issue.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Lisa Inserra
    March 13, 2013 at 5:10 pm
    Actually, it’s only when I turn on 3D…even without the camera. I have a plug-in called 3D assistants that’s kind of old. Could that be making the problem?
  • Roland R. kahlenberg
    March 13, 2013 at 5:14 pm
    It sounds like your camera’s Depth of Field is switched on. Double-click the camera layer or reveal the camera settings in the timeline and switch off Depth of Field.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects ACE/ACI (version 7)
  • Lisa Inserra
    March 13, 2013 at 5:16 pm
    I uploaded the image. Hope you can see it.
    don’t know if you saw my last amended note. It also looks like a dissolve mode when I turn on 3D – even without the camera.
  • Lisa Inserra
    March 13, 2013 at 5:18 pm
    Here’s the link to how it looks
    Yes, depth of field is on, but new information, it happens when I just turn on 3D even without the camera.
  • Lisa Inserra
    March 13, 2013 at 5:19 pm
    Hi Vishesh, I’ve embedded this image. Hope you can see it.
  • Vishesh Arora
    March 13, 2013 at 5:39 pm
    Hi Lisa
    Try deleting that plugin. Also Select all the Layers in present comp, Cut them and Paste into a New Comp. And check the Results.
    Also you have not posted the Timeline in the Sceenshot.
    Vishesh Arora
    Films Rajendra
    Blog:
    2011 3D Demo Reel:
    March 13, 2013 at 8:11 pm
    When a 3D layer is created and there is no camera layer, AE will renders the 3D layer with an/a imaginary/proxy camera with parameter values such that the 3D layer maintains its 2D size. This is expected behavior.
    It’s quite likely that your layers have been moved closer to the camera after you made those layers 3D.
    BTW, I am doubtful that the old plugin is causing this issue. Additionally, you can prevent AE from loading a plugin by enclosing its name or folder in parentheses – like this(plugin_name).
    HTH
    RoRK
  • Paul Roper
    March 14, 2013 at 8:49 am
    That noisiness is caused by your raytracing quality set too low – nothing to do with plugins or camera depth of field (although if you turn off depth of field you’ll notice it less, but any motion blur will also appear noisy).
    To fix it, go to Composition Settings (command or control K), clcik on the Advanced tab, click on Options… and set your Raytracing quality to a higher number. The higher the number, the slower the rendering but the better the image. You’ll have to decide how high you can go vs. how long you can wait! Don’t go crazy – I’d guess from your image that it’s probably on about 4; maybe go to 8 or 12 – anything much higher and you’ll be waiting for hours for your render to complete!
    – Paul
    March 14, 2013 at 12:52 pm
    [Paul Roper] “That noisiness is caused by your raytracing quality set too low”
    Good catch Paul. I missed the ray-tracing noise issues along the edges.
    Cheers
    RoRK
