Activity › Forums › Adobe After Effects › camera keyframes
  • camera keyframes
    Posted by Mark A. stuart on January 11, 2013 at 3:32 pm
    Hello,
    The camera in my AE doesn’t seem to be keyframing. I’m still learning
    the camera, but according to all the tutorials I’ve seen, I’m doing this
    right. Please let me know what I’m missing or what the problem could be
    here.
    Making a very, very simple example-
    •I create a new solid in a new composition, creating a rectangle (not
    even using a background here for simplicity).
    •I make sure the Pan Behind is in the center of the object.
    •I put the rectangle layer in 3D.
    •I create a new camera-my settings there are:
    35mm
    zoom 840
    film size 102.05
    focal length: 99:21
    lock to zoom
    units: pixels
    measure file size: horizontally
    •I place a keyframe at the beginning of the camera track by hitting the
    stop watch next to “Position”.
    •Next, I scroll into the comp a couple seconds and move the object all
    the way to the edge. I repeat this every 2 seconds in my 10 second comp,
    bringing it back and forth from edge to edge. I’m doing this with the
    “Track XY Camera Tool”. The object moves from edge to edge when I’m
    placing the keyframes.
    •However, as soon as I scroll the cursor back to the beginning of the
    comp to even just drag it to the right to look at it, the object remains
    sitting on the far right edge and wiggles back and forth slightly!
    Doesn’t even resemble anything I have keyframed. It does the same thing
    if I do a RAM preview.
    I wish I had a screen recorder to show you but don’t (and I doubt the
    company I work for would allow me to download one) so hopefully I
    explained this accurately, but basically the position keyframes in the
    camera don’t seem to work, or execute. They go in there fine when I move
    the cursor and then the object, but they don’t “take”-don’t work when
    played back.
    I read somewhere about advice to be sure “auto orient” is selected. I
    also tried this and the same thing happened.
    I’ve tried several fresh projects, restarted the PC and updated it. Maybe camera settings?
    Any suggestions?
    thanks much!
    -Mark
    Mark A. Stuart
    Producer/Director/Editor
    Madison, Wisconsin
    USA
    Mark A. stuart replied 13 years, 8 months ago 2 Members · 2 Replies
  • John Cuevas
    January 11, 2013 at 3:44 pm
    If it’s just a rectangle for now, save the project and upload it here(last icon in the message box). I’ll open the project and take a look at what you are doing.
    By the way, UW Alum, On Wisconsin!
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Mark A. stuart
    January 29, 2013 at 9:04 pm
    thanks, John. Sorry it took so long to get back here-turns out on our CS3 I just needed to adjust “point of interest” instead of “position” like the 2 or 3 tutorials I watched told me to!
    -Mark
    Mark A. Stuart
    Madison, Wisconsin
    USA
