Activity › Forums › Adobe After Effects › Camera keyframes changing by themselves…
  • Camera keyframes changing by themselves…
    Posted by Roc Barbanica on October 26, 2006 at 8:45 pm
    I have a camera keyframed out for a few seconds, pause it(dupe last keyframe) then make it move again. when I do that, all the keyframes before change… WHY? Please help.
    Roc Barbanica replied 19 years, 11 months ago 3 Members · 5 Replies
  • Chud13
    October 26, 2006 at 9:29 pm
    I think if you right click on the keyframes (PC) then on keyframe interpretation, then change spatial properties to linear that will fix it. If you then want to mess with easy ease and such, change it back.
  • Roc Barbanica
    October 26, 2006 at 9:50 pm
    stopwatches engaged… I set the cam position and orientation, move up in time, change position and orientation, do it again. I move the play head back to position one (keyframe one) and it is not where I placed it, neither is KF2.
    I was using one of the tutorials on CC by A. Kramer
    https://forums.creativecow.net/articles/kramer_andrew/reflections/reflections.htm
    Anyway, at the end, he moves the cam – I tried to take it a bit further but got whacked results as I stated above.
  • Roc Barbanica
    October 26, 2006 at 10:25 pm
    Temporal and spatial are linear. locked to time. Obviously I am a rookie and I thank you for your time. Can I send you the aep file? 🙂
  • Mark
    October 27, 2006 at 1:46 am
    You are not clicking on the camera’s position in the timeline are you ? This would cause all keyframes to be highlighted and as such be affected by any movement you make.
    Mark
  • Roc Barbanica
    October 27, 2006 at 3:56 pm
    Thanks everone for you help.
