Activity Forums Adobe After Effects Expressions camera / keyframe interpolation
  • camera / keyframe interpolation
    Posted by Wim Roegels on June 15, 2006 at 11:11 pm
    this is bothering me for a couple of projects now and I was everytime able to fix this, but I didn’t really know how I did it. This is a very basic question, but a hint would help me alot …
    I have the problem, that I have two keyframes controling the position of a camera in 3d space … the only value which is changing is the Z Value of the position, X and Y should keep their values. What I want to have is a ‘ease in’ for the Z value, but the others X&Y should stay as they are … is there a way to only edit ONE Value of a Positon keyframe?
    Unfortunatly – as you can see on the screenshot – X and Y change also slightly …
    https://www.diealtenzeiten.de/ae_sshot.jpg
    Best regards
    wim
    Wim Roegels replied 20 years, 3 months ago 2 Members · 2 Replies
  • Steve Roberts
    June 15, 2006 at 11:17 pm
    Use 3 nulls: one for X, one for Y and one for Z. Using an expression, tie each position parameter for the camera to the relevant position parameter for each null. For example, tie the camera’s x-position to the X null’s x-position.
    For more info, search the COW for “null” and “expression” and “3D”. You might also want to include “Smith” as the author.
  • Wim Roegels
    June 16, 2006 at 10:11 am
    Thanks for your answer Steve.
    I was aware of better using NULLs to control a camera in AE … but I thought I am doing something wrong.
    Strange interpolation anyway.
    Thanks again.
    Best regards
    wim
