Activity Forums Adobe After Effects camera info to path
  • camera info to path
    Posted by Chris Abolt on December 8, 2009 at 7:34 pm
    Hi all, I am wondering if there is a technique or expression that will take the properties of a camera x,y,z
    and convert them into path data. This way I will have a path in exactly the same length, direction and orientation as the camera??
    I am very familiar with the opposite of taking a path shape to position keyframes.
    Thanks in advance
    Chris Abolt
    Motion designer
    Abolt Media
    Alex Dinnin replied 16 years, 9 months ago 3 Members · 2 Replies
  • Bartek Skorupa
    December 8, 2009 at 7:55 pm
    This works only in two dimensions. There is no way in AE to establish 3d path.
    If you take a 2d layer’s position copy all it’s keyframes and paste it to the mask’s path or shape layer’s shape – you got the path, but if you do it with a 3d layer – it will take only x and y, and simply ignore the z value.
    Bartek Skorupa
    Warszawa, Poland
  • Alex Dinnin
    December 9, 2009 at 11:59 am
    A way round this would be to copy the camera’s x & y position onto a mask, then use an expression for your object to follow only the camera’s z position…
    if you need me to I can knock the expression up for you
    Alex
