Activity Forums Canon Cameras Camera I can use with Infrared
  • Camera I can use with Infrared
    Posted by Rob Mcwilliams on September 7, 2010 at 2:38 am
    I have an upcoming shoot where I need 6 camcorders to do night shooting. Shooting in pitch black but will be using infrared illuminators.
    Any ideas?
    I like the canon cameras as I can get longer record times with SD cards.
    Thanks in advance.
    Brian Louis replied 16 years ago 2 Members · 4 Replies
  • Brian Louis
    September 7, 2010 at 12:06 pm
    Are you going to be shooting in HD or SD? Pro cams or consumer?
  • Rob Mcwilliams
    September 7, 2010 at 6:32 pm
    I’d love to shoot HD, but record times are an issue.
    If no HD then at least 16×9. Is there such a beast?
  • Brian Louis
    September 7, 2010 at 7:39 pm
    Most of the Canons sold now only have a low light mode listed, same for Sony, the Canon SD version cams(fs31,fs300) have a “Night Mode” listed, but whether this is a true “Night Shot” mode where the IR filter is removed from the optical path or a slow shutter mode you would have to check with Canon Sales to verify it.
  • Brian Louis
    September 14, 2010 at 10:45 am
    I just noticed that part of the message I had posted did not show up, but what I added was that alot of the sony consumer cams have night shot modes, I know the HC3/5/7/9 series and the some of the tapeless consumer cams have a nightshot function, I don’t know about the most recent ones
