Activity Forums Audio Camera frame rate effect on audio
  • Camera frame rate effect on audio
    Posted by Jim Mcnally on July 28, 2010 at 1:44 am
    For years my camera recording 29.97 frames of video happily captures the audio in perfect sync. Now with DSLRs, more shoots are being done at 23.98.
    When using a digital recorder such as a Zoom H4N is there a setting to indicate what frame rate is being recorded on the camera side? I know I want it at a 48K sample setting but do I need to worry about the camera frame rate?
    thanks,
    Jim McNally
    The Commercial Factory
    http://www.commercialfactory.com
    Ty Ford replied 16 years, 1 month ago 3 Members · 3 Replies
  • Sam Mallery
    July 28, 2010 at 2:29 pm
    There is no frame rate setting in the Zoom H4n. Most consumer portable recorders don’t have frame rate settings. I researched what settings people were using with success with the H4n, and I found equal praise for 48kHz 24-bit and 48kHz 16-bit.
    Personally, I always set my recorder for 48kHz 24-bit and so far everything has been going smoothly.
    http://www.sam-mallery.com
  • Jim Mcnally
    July 28, 2010 at 2:38 pm
    Great, thanks for your response Sam.
    Jim McNally
  • Ty Ford
    July 29, 2010 at 1:22 pm
    Jim, Sam,
    I did have a near space anomaly recently that I can’t explain fully.
    I ran a Canon XL2 for an hour and also recorded audio to a Sound Devices 744T. The 744T was set to 30 fps NDF
    In the current version of FCP, the 744T track was out of sync with itself. That is, when I visually aligned the waveforms of the XL2 and 744T, the audio from the 744T was not in sync with itself.
    That is to say that when I soloed the 744T and watched and listened as those tracks played, the sound I was hearing was not synced to its own waveform.
    I used wave agent to change the frame rate to 29.97 and the sync problem went away.
    I don’t know if this was due to a idiosyncratic glitch or not. I have not had time to experiment further.
    Time code is only stamped at the header in file-based audio. There is no longitudinal time code, so, over time, there is no continuous sync.
    The 744T does have a setting for no time code I wasn’t aware of. So it can record w/o time code.
    I know this may muddy the water a bit, but I thought I should put it out there.
    Regards,
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Watch Ty play guitar
