Activity Forums Broadcasting Camera for broadcasting
  • Camera for broadcasting
    Posted by Karl Walker on April 22, 2011 at 9:59 am
    Hi! I’m Karl and I am new here.
    We have a church and we are planning to record and broadcast on satellite tv some of our worship services.
    Could you please recommend a camera for me? We have a budget of about $1500 for a start.
    Someone recommended the Panasonic TM700 or so…..any advice?
    Karl Walker replied 15 years, 4 months ago 6 Members · 13 Replies
  • 13 Replies
  • Bouke Vahl
    April 24, 2011 at 9:18 am
    eeer, dude…
    I don’t get it.
    What is the price for a sattelite uplink at your location?
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Karl Walker
    April 24, 2011 at 1:01 pm
    I will be sending the finished product to a church in South Africa and it will be broadcast on sat TV (intelsat 7/10) through them. There is a package for budget broadcasting.
  • Richard Cardonna
    April 24, 2011 at 5:13 pm
    For that price i their are various low end prosumer cams from panasonic and sony. check at bhphoto.com, Or go to ebay and buy a higher end used cam.
    Will you be sending a recording via mail or streaming or sending a live feed?
    rcm
  • Bouke Vahl
    April 25, 2011 at 10:29 am
    well, my point was, for 1500 bucks you have money to record just the sound…
    iow, make a list of all the equipment you need, and don’t forget cabling.
    You need a camera, tripod, mics, something to get the material inside your computer for post, some storage, means of transportation to the broadcaster…
    And i take it the operators are volunteers?
    Bouke
  • Rafael Amador
    April 26, 2011 at 10:07 am
    Buy your self any camcorder with FW, plug it to a lap-top and you are done.
    rafael
    http://www.nagavideo.com
  • Karl Walker
    April 26, 2011 at 10:31 am
    What is FW?
    I am currently using a small camcorder to rec d video and my laptop to rec d audio on audacity thru line out from d mixer. I use sony Vegas pro 10 to mix it and make dvds
  • Richard Crowley
    April 26, 2011 at 2:01 pm
    FW = FireWire = EIA1394 = iLink(Sony)
    What does your current video product look like? Sound like? What are the major deficiencies? Maybe lighting or microphone or even set dressing are more “low-hanging fruit” than replacing the camera.
    You have asked our opinion about a specific camera, but you have given us no context in which to evaluate it. What do the people at the uplink say about your video? I suspect that people here are reluctant to answer your question because from our perspective you are asking it in a vacuum. You haven’t even identified your current camera or what kind of video you are shooting? Are you doing “simple” interior talking-head? Or are you producing worship services? Or are you making on-location documentaries? Where are you?
  • Karl Walker
    April 26, 2011 at 2:36 pm
    Sorry, I’m new to this and still trying to work out things.
    I am using a small Panasonic SDR-H40 camcorder right now to make simple videos of the preaching in the church.
    I am recording the sound through the audio line out on my mixer to my laptop using audacity. I then convert the sound to MP3 and mix it with the video using Sony Vegas.
    This is one of the videos I recently made – https://youtu.be/ezwFyT9nm-o
    I am planning to start sending dvds for broadcast by the end of this year and I would like some advice as to what to pick up.
    The uplink guys want me to use at least a 3ccd camera……the one I am using is not, hence I need to pick up another one.
    The camera I am using is a very small one and it records in mov. format. I mix it on Sony Vegas and render it as avi. format PAL DV widescreen (don’t know if that is correct or not).
    I will not be producing documentaries, but simple recordings of the preachings.
    I am located in Mauritius.
    Hope this helps a bit…:-)
  • Richard Crowley
    April 27, 2011 at 1:32 am
    Have you tried your camera outdoors? What kind of video do you get on a bright overcast day? What does the picture look like when you keep the zoom at a conservative setting (i.e. not all the way out at 42x) Many lower-cost cameras produce remarkably nice pictures when what they are shooting is well-lit. The video I saw had bright white backgrounds which will make even the most expensive camera produce muddy images because cameras (and humans, for that matter) don’t tolerate bright back-lighting interfering with the primary subject.
    I assume that the distortion I heard in the audio is from the YouTube compression? Does your original audio sound OK?
    I wouldn’t automatically jump to the conclusion that you need a new camera when you appear to have lighting issues to remedy first.
  • Karl Walker
    April 27, 2011 at 3:23 am
    Hi Richard,
    Yes, I tried the cam outdoors and the image is very clear.
    The audio on my side is quite clear, so I guess it is a thing with Youtube when I uploaded it.
    I will try with a darker background and see how it comes out.
    Thanks a ton….I appreciate all the advice..
    Karl
