Activity Forums Adobe After Effects Camera follows path and illustration – Z space /
  • Camera follows path and illustration – Z space /
    Posted by David Chaudoir on June 11, 2009 at 4:07 pm
    Imagine if my illustration is of a slot car/scalextric track with zig zags and curves.
    So I bring that in from Illustrator. Then I copy the path and use that as a motion path in a null.
    So I can attach the camera to the null and I get a certain effect – but not the one I’m after.
    What I want is the view from the car – a few inches up from the “road” looking at the road and following the twist and turns as it unfolds. The road is not flat but tilted as if on a horizon line… I’m finding it very difficult to achieve.
    Seen a tutorial for this anywhere…. useful expressions, Project files?
    Any help gratefully recieved.
    David Chaudoir replied 17 years, 3 months ago 2 Members · 3 Replies
  • Brian Charles
    June 11, 2009 at 5:40 pm
    Rick Gerhard had 2 tutorials on the Cow dealing with this exact technique, I’ve done a cursory search but can’t locate them.
    The technique Rick uses is to tie the camera’s POI to a null with a simple pick whip expression. Animate the camera position and then the null. Its best to position the null at the camera’s intended eye level first.
    Sorry I can’t find the tutorials on line.
  • David Chaudoir
    June 11, 2009 at 5:46 pm
    ….. bump
  • David Chaudoir
    June 11, 2009 at 5:52 pm
    Thanks for that…yes the link is dead.
