Activity › Forums › Adobe After Effects Expressions › Camera following a layer that is moving in 3D space
  • Camera following a layer that is moving in 3D space
    Posted by Firestarter3000 on December 31, 2006 at 3:20 pm
    I have a layer that contains a 3D rendered animation.
    This layer needs to move through after effects 3D space always facing the camera in the right angle (front, flat).
    I would like to be able to rotate this layer, etc.
    I tried two things that didn’t work out for me so far.
    > Solution A
    – The position of the layer is the same as the camera’s POI (via expression).
    – The layer is set to “Orient towards camera”
    – The amera itself follows the POI path with a time delay (via expression)
    FollowPoint = thisComp.layer(“CameraMove”).effect(“LookAhead”)(“Slider”);
    position = transform.pointOfInterest.value_at_time(time-FollowPoint);
    – I animate the POI of the camera, layer and camera follows
    PROBLEM, as soon the layer (POI) stops the camera comes closer to the object.
    > Solution B (seems quite complicated; haven’t worked the right expression out yet)
    – The layer (with the 3D animation) moves and rotates through space followed by the camera always facing in the same angle the layer. (please see also: http://www.emqu.de/docs/AEtask.jpg)
    – A cameraDistance variable controls the distance of the camera towards the object.
    Any suggestions or solutions?
    thanks
    And happy new year.
    markus
    Firestarter3000 replied 19 years, 9 months ago 2 Members · 2 Replies
  • Dan Ebberts
    December 31, 2006 at 11:57 pm
    Have you tried just making the layer the parent of the camera?
    Dan
  • Firestarter3000
    January 1, 2007 at 5:42 pm
    Hi Dan,
    Doh!
    Didn’t see the most simple solution, by overcomplicating it.
    Well, it was late, I was tired, end of the year, etc. 😉
    markus
