Camera flat facing 3D object in 3D motion tracked footage
Hi there,
First post ever in the forum, would appreciate a lot your help because I can’t seem to find a solution to something I want to achieve.
I have a shot taken with a drone that is just rotating in the air. I have used the motion tracker to generate a camera and tracking points to attach some text/objects to. The issue is trying to make these objects face flat to the camera at all time. The Layer:Transform:Auto-Orient doesn’t seem to work, of course, the generated camera is not really moving, its just simulating the footage perspective!!
2D tracking is not an option. I want the objects to exit the screen naturally, as they would do if they were really integrated in the shot.
Can this be done??
Any help would be awesome. Thanks!!!
