Activity › Forums › Adobe After Effects › camera flash
camera flash
Posted by Dotan Baytman on December 21, 2006 at 5:04 pmi have a cell phone i wanna add an effect of a camera flash from the camera
what is the best way to create it?
lens flare?
i need it to be as much realistic as it can
thanxSteve Morris replied 19 years, 9 months ago 3 Members · 6 Replies -
Steve Morris
December 21, 2006 at 5:40 pmI have created a fairly realistic camera flash by using a lens flare and white solid with an expanding feathered irregular star shaped mask. I used it as a transition, so I had it completely fill screen. I ramped the opacity up very quick, within a couple of frames. I then ramped the opacity back down just a little slower. It “looked” a lot better when I added the shutter noise effect.
I am not an expert. See what others have to say. I am sure there is a better way.
Mike Clasby
December 21, 2006 at 7:42 pmEffect Essentials used to have a freebie named EE Camera Flash (alas no more), but if you scroll on Aharon’s head at the top, the graphics commando (see camo hat) and scroll down to “Creating a Film Flash Transition”, you can do the same thing. Don’t use it as a transition, just go back to the same image.
Dotan Baytman
December 22, 2006 at 10:53 amCan you describe in alittle more details please?
i mean one solid lens flare which lens?
second layer white solid with star mask shape
then what? -
Dotan Baytman
December 22, 2006 at 2:45 pmOk i figuerd it out
i used lens flare on a black solid
but how can i hide the black around it?
thanx -
Steve Morris
December 22, 2006 at 5:21 pmSorry, I thought my simple explanation was enough. You have to apply the lens flare to some type of a layer as you did. If you applied it to a black solid, you need to then use something like Knoll unmult, or use a blend mode such as screen to get rid of the black.
I think you can download Knoll unmult for free. Do a search for it. It will magically make the black go away. A blending mode will do similar.
Let me know if you need more details on the star shaped mask which is on another layer (white solid).
Steve Morris
December 22, 2006 at 5:26 pm
