Activity › Forums › Adobe Premiere Pro › Camera flash effect
Camera flash effect
Posted by Robert Bec on February 22, 2006 at 6:18 amis there a camera flash plugin effect for prem1.5
Robert Bec replied 20 years, 6 months ago 4 Members · 6 Replies -
Steve Morris
February 24, 2006 at 1:12 amI made my own camera flash that I use as a transition at times when I am “capturing” a frame from video and holding it as a still.
I used the lens flare combined with a white starburst made in Photoshop. I keyframe the size from a small point, to large enough to cover the entire frame. I also keyframe the brightness of the lens flare. Then sycle it all back down again. This all takes place in less than 1/2 sec. I then add a wav file of a camera sound. It comes off pretty realistic.
James Stone
February 24, 2006 at 2:08 pm -
James Stone
February 25, 2006 at 2:05 pmwell it looks like you have to apply the effect to both clips. Then you adjust the intensity rom say 0 to 50 until it whites out the screen on clip A . The on clip B do the opposite go from 50 to 0 using key frames. I just discovered it and thought it was a true transition that covered both clips at the same time.
