Activity Forums Boris FX Camera effect
  • Camera effect
    Posted by Sergio Anaya on July 24, 2007 at 11:25 pm
    I am trying to make an effects, for sure you have seen it before; that I am trying to do is to see one video and then the effect is as the camera moves to the rigth and there seems there is another video waiting, and then the camera moves againg in any direction rigth,left, up or below and there is another video and go on, I am trying with only V1 and V2 and added a 3D container but I have not sucess, can someone tell me how to do this?
    Thanks, help is welcome.
    Erik Hermesman replied 19 years, 1 month ago 3 Members · 4 Replies
  • Peter Mcauley
    July 25, 2007 at 5:37 pm
    If you send me your email address I’ll send you a project – my email address is peterm@borisfx.com.
    This effect is achieved by adding the tracks that you want to pan into a 3D container and offsetting the clips so that they are touching only along the edges. Then you set the camera to pan mode and animate the camera along the X or Y axis so that the camera pans across the images in succession.
    Alternately, you might want to drop the image clips into a title container and select the shuffle mode, which will automatically shuffle the clips over the length of the composition.
    Cheers,
    Peter.
  • Sergio Anaya
    July 26, 2007 at 3:45 pm
  • Erik Hermesman
    July 31, 2007 at 3:18 am
    Peter,
    would you mind sending me the files too?
    erhpaintball AT aol DOT com
  • Erik Hermesman
    July 31, 2007 at 3:20 am
    Oops that should be
    erhpaintball29 AT aol DOT com
    Thanks.
