Activity Forums Adobe After Effects Camera Data from Lightwave to After Effects
  • Camera Data from Lightwave to After Effects
    Posted by Rebel_alliance on August 8, 2006 at 4:48 pm
    Hello everybody,
    I am trying to transfer a camera move from Lightwave to After Effects. I rendered both as rla and rpf (using the image processing filter) I imported it into AE. I created a composition by dragging the 3d render in the comp icon so I have the same parameters. After that I right clicked and selected Keyframe Assistant/ RPF Data. AE translated the data and created a new camera but the movement is not the same. The camera is not oriented correctly and some of the movement is missing. I tried a simpler move such as moving the camera only in the z axis. Again the movement is transfered but is hardly noticeable (the camera moves only slightly in the z axis in AE). I tried changing the pixel aspect ratio to square pixels, I changed the measurment units from SI to English but nothing seems to work. Does anyone know the solution to this one?
    Mylenium replied 19 years, 10 months ago 3 Members · 2 Replies
  • Steve Roberts
    August 8, 2006 at 4:54 pm
    Search the COW for Transmotion.
  • Mylenium
    August 8, 2006 at 5:43 pm
    Lightwave’s RPF/ RLA savers do not work properly. Just get Transmotion like Steve said.
    Mylenium
    [Pour Myl
