Activity Forums Telestream Camera coming up as black screen
  • Camera coming up as black screen
    Posted by Drew Delany on August 9, 2013 at 2:07 pm
    Hi Guys,
    Got a problem with a set-up. Place I work has just bought Wirecast and is trying to connect their Blackmagic Cinema Camera to it via thunderbolt to use for live streaming.
    I installed the drivers for the camera and Wirecast has it in the add source menu but when I add it it comes up black. Camera is on and showing something, works with media express and ultrascope, but not in wire cast.
    I’m using a brand new macbook with OSX 10.8.3, Wirecast version 4.3. Camera is set to ProRes 25fps as is wirecast and all other inputs work.
    Any thoughts??
    Cheers,
    Drew
    Craig Seeman replied 13 years ago 2 Members · 1 Reply
  • Craig Seeman
    August 9, 2013 at 2:30 pm
    I had talked to Blackmagic about this awhile back. They’d have to make a driver to support it so they said at the time.
    You should certainly be able to use the camera’s SDI out and go into the Mac with a Blackmagic UltraStudio MiniRecorder.
    BTW I’d strongly recommend staying current.
    OSX 10.8.4
    Wirecast 4.3.1
    Blackmagic driver 9.7.7
