Activity Forums Adobe After Effects camera blur
  • camera blur
    Posted by Ray on February 20, 2006 at 5:55 pm
    I’m moving the camera rapidly through a scene, coming to rest in front of a small object. I thought that the rapid camera movement would create motion blur as it flies toward this object, but instead each frame is clear. Is there a way to turn this on? Do I have to adjust the camera settings? Or do I fake it with a radial motion blur?
    I tried to search but my browser is acing up.
    Ray replied 20 years, 7 months ago 4 Members · 5 Replies
  • Chris Smith
    February 20, 2006 at 6:28 pm
    You mean the AE camera, yes? Yeah, just turn on motion blur. In the composite settings you can set it higher than the 180 degree of a normal film gate, but 180 is usually plenty unless you are going for a non-natuaral extreme look.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Ray
    February 20, 2006 at 7:41 pm
    Ummm…right…turn on motion blur….
    But where is that again? There isn’t a motion blur swatch for the camera layer in the timeline, and the only blur setting I see when I open layer –> camera settings is when I enable depth of field, which is a different type of blur (correct??).
    I guess I don’t know what you mean by “composite settings.”
  • Bobby Mosaedi
    February 20, 2006 at 9:06 pm
    its in the timeline next to the source name (the three little circles between the film and the half-moon). you have to check it on for each layer that you want the motion blur applied to
  • Steve Roberts
    February 20, 2006 at 10:21 pm
    That is, apply motion blur to the layers that the camera sees, even though they’re static, and the camera is moving.
    Steve
  • Ray
    February 20, 2006 at 11:01 pm
    Aha!
    Thank you!
