Activity Forums Maxon Cinema 4D camera animation: where are spatial interpolation tangents??
  • Dave Glanz
    January 16, 2010 at 9:18 pm
    I’m not completely sure – but I think the spatial tangents are controlled in the timeline with curves.
    https://www.daveglanzproductions.com
  • Alan Lacey
    January 19, 2010 at 11:41 am
    I’m sure I’ve done this in the past Johan.
    From memory but converting the camera path to a spline, modifying that and then converting back to path.
    Alan (uk)
    FlashXDR,XDcamHD,XDcamEX,D9 etc
    FCS,AE,Combustion,LiquidSilver,Vegas,Edius,
    G5,MBP,Vista64,XP
  • Johan Hoogendoorn
    January 21, 2010 at 7:16 pm
    thanks I’ll try tomorrow!
    C4D – AE – PS – IL
  • Alan Langdon
    May 14, 2010 at 11:53 am
    Johan, did you ever figure this out? I too have found them by accident, but can’t seem to see them anymore (camera spatial interpolation handles, as in AE). It should be SO simple, as you say, but I am missing something here… Please let me know if and how you solved this?
  • Alan Langdon
    May 14, 2010 at 11:54 am
  • Carol Ferry
    July 3, 2010 at 1:00 am
    It’s crazy nobody can answer this, I’ve been looking everywhere on the web. It’s probably not the right wording. Folks coming at Cinema from an AE point of view, looking for spatial keyframe control within the viewport. I just can’t find the tangents to control the movement. How is this so hard? Please Cinema people, help!
  • Brian Jones
    July 3, 2010 at 4:08 am
    Well, there’s the Timeline in F-Curve mode but if you’re looking for direct manipulation of the animation path in the viewport – select the keyframe on the animation path, if it doesn’t have a handle or if you can’t move the handle uncheck Auto Tangents. If the handle wasn’t there make the Left or Right Value something non-zero. Grab the handle with the Move tool.
  • Carol Ferry
    August 2, 2010 at 4:08 pm
    Thanks so much for your reply, Brian –
    this helps – even though I still find it so confusing in Cinema, so much easier in AE.
    Will get used to it. THANKS!
  • Loay El-aswad
    July 17, 2012 at 11:01 am
    I’ve been wondering about this for about 2 years :)! (using splines to animate)
    Thank you Very much
