Activity Forums Adobe After Effects Camera and Lights in Pre-Comp are lost
  • Camera and Lights in Pre-Comp are lost
    Posted by Mike Hayes on July 13, 2007 at 12:48 am
    ***I’m sure this has been discussed before but I’ve done a bit of searching and couldn’t find anything….
    I have created a composition with an animation incorporating a light and camera and dropped that into another comp which contains the lower third I wish to use.
    However my camera and lighting have disappeared!
    Are Camera’s and Lights allowed to be used in Pre-Comps?
    Cheers
    Mike
    Steve Roberts replied 19 years ago 3 Members · 4 Replies
  • Steve Roberts
    July 13, 2007 at 1:01 am
    Did you check the AE Help section on 3D and “collapse transformations”?
  • Mike Hayes
    July 13, 2007 at 1:20 am
    YES! (no…)
    Thanks, It was the opposite to what I expected, I had set ‘Collapse Transformation’ instead of having it unchecked. Sometimes I just do these things without understanding why they work…
    Thankyou.
    M
  • Darby Edelen
    July 13, 2007 at 1:24 am
    [Hazestudios] “I have created a composition with an animation incorporating a light and camera and dropped that into another comp which contains the lower third I wish to use.
    However my camera and lighting have disappeared!”
    If you have ‘Collapse Transformations’ turned on for your pre-comp then any cameras or lights in that pre-comp will not apply when that pre-comp is viewed in another composition.
    If you don’t need your pre-comp to maintain its 3D-ness in your final comp then don’t enable ‘Collapse Transformations’ (it will, of course, still ‘look’ 3D because it is made of 3D elements, but it will be displayed on a 2D plane).
    If you still want to use ‘Collapse Transformations’ then you need to move your lights and your camera into the final composition and they will properly affect your pre-comped 3D elements (assuming that they are set to accept lights in the pre-comp).
    The other thing to check is that you don’t have ‘Draft 3D’ enabled in the composition (I think it’s 2 buttons left of the ‘Motion Blur’ button above the timeline).
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Steve Roberts
    July 13, 2007 at 2:35 am
    [Hazestudios] “Sometimes I just do these things without understanding why they work…”
    Heh … you and me both. 🙂
    (Oh, what a giveaway…)
