Activity Forums Maxon Cinema 4D Camera Aligned to Spline
  • Camera Aligned to Spline
    Posted by Emma Walker on May 25, 2022 at 12:52 pm
    Hi I am doing a flythrough using a camera aligned to a spline. The length is approx 30 secs. I have noticed when I adjust the splines path it affects the cameras position/rotation earlier on in the time line. Is there a way I can fix/lock the cameras position on the spline.
    Justin Thomson replied 4 years, 4 months ago 2 Members · 1 Reply
  • Justin Thomson
    May 25, 2022 at 3:36 pm
    As you adjust the spline the object aligned to it will adjust itself to reach the next keyframe. You might want to try keyframing the “position” to get your timing down.
