Activity Forums Adobe After Effects Camera affects only objects, not the background.
  • Camera affects only objects, not the background.
    Posted by Kurisuta Vd wilk on June 17, 2013 at 1:20 pm
    Is there a way to set up a composition with a camera and lights and some objects, where the cameramovement does NOT affect the background, but does only affect the objects.
    When I make the background go 2D ( so the background stays staidy like I want it to ) the shadows and light effects are not visible on the background since it is not 3D anymore.
    Thanks in advance !
    Krista
    No knowledge is a Statement
    Barry Rubin replied 13 years, 3 months ago 5 Members · 6 Replies
  • Roland R. kahlenberg
    June 17, 2013 at 2:42 pm
    Todd’s got the Lights covered – ie Accept Lights property. For the Camera part of your Q, simply parent the background layer (3D layer) to the camera.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE
  • Walter Soyka
    June 17, 2013 at 2:43 pm
    Make the background 3D, position is backwards in Z-space as necessary to clear foreground elements, scale it up to fit the frame, and parent it to the camera. When the camera moves, the background will move with it. From the camera’s perspective, it will remain steady.
    Walter Soyka
  • Kurisuta Vd wilk
    June 17, 2013 at 3:04 pm
    the parenting is very helpfull thanks !
    Only Todd deleted his message so I couldnt see what he said, any way you could repeat it ?
    Thanks !
  • Darby Edelen
    June 17, 2013 at 6:20 pm
    What I’d usually do in this situation is set the background 2D and position it as you like.
    Then you can use a 3D white solid (or several) with Accepts Lights: Off and Accepts Shadows: On set to the Multiply blend mode above your 2D background. You can position the 3D white solids as you see fit to get the best shadows possible.
    This separates the shadowing and the color/transform properties of your background.
    Darby Edelen
    June 18, 2013 at 12:13 am
    Darby’s solution is also viable – actually I’ve used it quite often but forgot to mention it in my earlier post. BTW, Todd mentioned using the Material Options property Accept Lights. You can set the BG ‘s Accept Lights property to Off.
    HTH
    RoRK
  • Barry Rubin
    June 18, 2013 at 2:49 pm
    Yes you can. Make the footage you to be effected as 3d layers and make the images you don’t want to be effected 2d layers.
