Activity Forums VEGAS Pro Camcorder not recognized
  • Camcorder not recognized
    Posted by Paul Gregory on August 31, 2013 at 2:13 am
    I haven’t use my Sony HDR-CX550 camcorder for several months during that time a few changes were make to my computer. What I’m finding that once I have the power plug & usb cord plugged into the camcorder nothing at all seems to happen. I don’t get the message that a new devise has been detected or hear the click.
    I went back to the often despised PMB software only to find its been replaced by My Memories pro. I installed this program & had the same no result. This new program from the little I saw of it is a step down from PMB.
    Is this problem likely to be a driver problem, camcorder problem or should I be looking elsewhere? I’m using Vegas pro 10 64 bit.
    Thanks in advance
    Paul Gregory replied 13 years ago 2 Members · 4 Replies
  • Steve Rhoden
    August 31, 2013 at 8:17 am
    You tried this update, under Windows 7 64bit?
    https://esupport.sony.com/US/p/model-home.pl?mdl=HDRCX550V&template_id=1&region_id=1&tab=download#/downloadTab
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • Paul Gregory
    September 1, 2013 at 1:36 am
    I tried this link & see that the camera model on offer is HDR-XR550V. The model stenciled on side of camera doesn’t have the ‘V’. I don’t know if this is significant or not.
    Because the PC isn’t seeing the camera at all I decided that it could not make matters worse. There are 3 files on offer. 2 are for PMB which I thought has now superseded & the 3rd for PlayMemories. None of these file look like drivers.
    I downloaded the PlayMemories & ran it. It was a file called PMHome. When it opened it displayed PMB rather than PlayMemories, which was confusing. Even more confusing is I asked PMB if it had updates it said there were none when the other day it basically said that PlayMemories had replaced PMB.
    Thanks in advance
  • Steve Rhoden
    September 1, 2013 at 2:20 am
    I’m suspecting something installed on your computer could
    be causing this disconnection with your Camcorder.
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
  • Paul Gregory
    September 2, 2013 at 7:08 am
    I have another old PC here which I connected up & did all of the updates for all of the software. I opened Playmemories & it said that my camera wasn’t registered & that I needed to connect it via USB which I did.
    Again nothing happened. I suspect that the problem is in the camera which plays perfectly except for this. Maybe I haven’t gotten the software switch set correctly or something like that.
    Should I be able to capture the latest files by just using Vegas Pro 10 without Playmemories software?
    I had hopped to show someone the video I shot last week before I go on an short overseas holiday next week.
    Thanks in advance
