Activity Forums Maxon Cinema 4D Cam target Q
  • Cam target Q
    Posted by John Kaley on February 12, 2007 at 3:35 pm
    I have a camera following a path with a camera target. Is there a way to have the camera 90 degrees above the camera target without having the camera auto-orient/rotate? Thanks!
    John Kaley replied 19 years, 6 months ago 2 Members · 2 Replies
  • Lennart Wåhlin
    February 12, 2007 at 4:30 pm
    You can try having a Null following the Spline then put the Camera as a child of that Null. Move the Camera up and tilt it down.
    Otherwise you might need to use a MultiTargetTag for the Camera.
    Cheers
    Lennart
  • John Kaley
    February 12, 2007 at 5:26 pm
    Excellent, thanks. I’ll use this method instead of the camera target.
