Activity Forums Adobe After Effects call script with shortcut
  • call script with shortcut
    Posted by Chortorn on February 8, 2007 at 9:12 pm
    Is it possible to call a *.jsx script from a shortcut that I will define in ‘Adobe After Effects 6.5 Shortcuts.txt’
    Is it possible to select another layer or layers from a script? How?
    Chortorn
    Chortorn replied 19 years, 7 months ago 2 Members · 2 Replies
  • Mylenium
    February 9, 2007 at 6:24 am
    [chortorn] “Is it possible to call a *.jsx script from a shortcut that I will define in ‘Adobe After Effects 6.5 Shortcuts.txt'”
    Yes. Look for entries like this in your ~shortcuts.txt file:
    “ExecuteScriptMenuItem01” = “()”
    All scripts must be at the root level of the scripts folder to show up in the menu and the menu order will be used.
    [chortorn] “Is it possible to select another layer or layers from a script? How?”
    Yes, it’s possible, but off the top of my head I don’t remember any part of the synatx.
    Mylenium
    [Pour Myl
  • Chortorn
    February 10, 2007 at 11:27 am
    Thanks for the quick replay.
    Does anyone know which method I should execute to select a layer?
    I have searched the scripting guide.pdf, but with no result so far.
    Chortorn
