Activity Forums Cinematography Calibrating two cameras to look the same
  • Calibrating two cameras to look the same
    Posted by Jasonjoseph on January 15, 2006 at 7:52 am
    Was just wondering if anyone knew the best way to calibrate two cameras, a HVR-Z1 and a HVRA1P ? At the moment the colour output from these cameras is different and brightness is different too.
    Also tips on setting up a monitor would be great.
    Newbie~
    Tony replied 20 years, 7 months ago 3 Members · 2 Replies
  • John Sharaf
    January 15, 2006 at 5:04 pm
    Jason,
    The best way to “match” two cameras is to use two of the same cameras! With professional cameras there are extensive controls like gains, gamma, ped, matrix, etc. that allow matching when both cameras are aimed a chip chart (with color patches for matrix) and observed on a waveform and vectorscope.
    Fo your purposes, it’s probably best to white balance on a common chart and do the matching in post.
    JS
  • Tony
    January 16, 2006 at 4:02 am
    Setting a common Iris for exposure goes a long way to make the images match also.
    Tony Salgado
