Activity › Forums › Blackmagic Design › Calibrating Monitor with Decklink Pro HD
  • Calibrating Monitor with Decklink Pro HD
    Posted by Bizatch on April 12, 2006 at 4:51 am
    I’m trying to calibrate my Panasonic BT-H1390YN monitor. When I hook it up to my DSR-1500A through S-video, I can calibrate it fine. When I use component cables hooked up to it from my Decklink HD Pro card, I can’t adjust the Phase. Any idea why?
    Adam
    Bizatch replied 20 years, 5 months ago 2 Members · 3 Replies
  • Jeff Brown
    April 12, 2006 at 1:12 pm
    Phase is not adjustable when using a component signal for any monitor that I know of. In a sense, there is no “phase” in a component signal the way there is in Y/C or composite.
    -jeff
  • Bizatch
    April 12, 2006 at 3:53 pm
    Thanks Jeff. I appreciate the help.
    Adam
  • Bizatch
    April 13, 2006 at 2:32 pm
    Well, I’m experiencing the green tint that others are seeing. Mine is not moving at all, so I don’t think I have a ground issue. It’s only green through the component cables.
    Adam
