Activity › Forums › DaVinci Resolve › Calibrating JVC DT-V24G1 24″
Posted by Frans Suijs on March 14, 2014 at 7:48 amHi,
I’m trying to calibrate a JVC DT-V24G1 24″ monitor with the JVC calibration software. Can anyone advise me on the settings I have to use? Target gamma, luminance & white balance.
Thanks in advance!!
Frans
Mario Moskon sarunic replied 12 years, 6 months ago 3 Members · 5 Replies -
Toby Tomkins
March 14, 2014 at 9:06 amFor broadcast rec709 work grading in a dim environment use a target gamma of 2.4, target luminance of 35 ftl / 120 cdm2 and a white temperature of 6500K
March 14, 2014 at 9:52 amFrans can you explain me how to calibrate DT-V24G1? I have same model and I would like to calibrate it but I dont know how to do it and what do I need :/
Frans Suijs
March 14, 2014 at 11:14 amThanks Toby,
That’s all I needed to know!! I don’t grade in a dim environment in which it is totally dark. Will the gamma/luminance and white temp will be suitable then?
Best regards,
Frans -
Frans Suijs
March 14, 2014 at 11:18 amHi Mario,
You’ll need the JVC calibration software: https://www.jvc-monitor-calibration.com It’s only for PC.
Then you need the Xrite i1, the OEM version, available at JVC. You need a serial port or USB-to-Serial adaptor for monitor communication and a HDMI to DVI-D cable for the video signal.
In the software you can use the settings Toby mentioned.
Best regards,
Frans
