Activity Forums Apple Final Cut Pro Legacy calibrating external monitor
  • calibrating external monitor
    Posted by Matt Shires on June 21, 2009 at 10:59 am
    Trying to calibrate my external monitor and have a couple of questions.
    1. Read a few different solutions on how to do it from various places and wondered if anyone had a preference?
    2. Once you’ve calibrated it with say 1080 50i colorbars would you then have to re calibrate if your next project was SD?
    Many Thanks, Matt
    Steve Oakley replied 17 years, 3 months ago 4 Members · 4 Replies
  • Walter Biscardi
    June 21, 2009 at 12:23 pm
    [matt shires] “1. Read a few different solutions on how to do it from various places and wondered if anyone had a preference?”
    Blue Only and set the bars accordingly.
    [matt shires] “2. Once you’ve calibrated it with say 1080 50i colorbars would you then have to re calibrate if your next project was SD? “
    Most likely.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Matt Shires
    June 21, 2009 at 3:49 pm
    Does it matter setting the Pluge bars with blue only after i’ve set the chroma and hue? or should i do the brightness and contrast first then the chroma?
    I’m possible making this way more tricky than it is?
    Cheers, Matt
  • Arnie Schlissel
    June 21, 2009 at 6:46 pm
    You should set the brightness, then set the contrast, then set the color.
    The FCP and Color manuals give a good step by step.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Steve Oakley
    June 22, 2009 at 5:36 am
    well this is where a MXO series product is nice – it can color manage the display and SD or HD, it doesn’t matter. it also means you can adjust from the MXO control panel which is also very handy
