Activity › Forums › Apple Final Cut Pro Legacy › Calibrated Software {Q} mxf import program
  • Jerry Hofmann
    October 21, 2008 at 2:50 am
    They have a demo version you could try… There’s no mention of Color’s ability to work with it… might ask them about it.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Andreas Kiel
    October 21, 2008 at 3:07 pm
    I haven’t tried it as well, same as you I didn’t find any comments/ratings about. But the feature list sounds impressive.
    The reason I didn’t try is that I got a running system with a similar but way more expensive component installed (mxf4mac). It works reliable and bullet proved here.
    But I would be interested as well how this works.
    Andreas
    Spherico
    https://www.spherico.com/filmtools
  • Eric Holzapfel
    October 21, 2008 at 6:27 pm
    Hello all,
    I will give it a try, I have downloaded the demo version, but not yet installed it.
    I will re-post with info after I try it.
    eric
