Activity Forums Apple Final Cut Pro Legacy Calibrated {Q} IMX Decode message
  • Calibrated {Q} IMX Decode message
    Posted by Atticus Brady on July 18, 2010 at 6:33 pm
    Hi everyone!
    Recently, when opening a Final Cut sequence, a message appeared within the thumbnail in the timeline that didn’t exist before. The message says “Calibrated {Q} IMX decode.” The message also pops up when trimming a clip. Does anyone know what this means and how to make it disappear?
    Atticus
    Atticus Brady replied 16 years, 1 month ago 3 Members · 4 Replies
  • Jeremy Garchow
    July 18, 2010 at 6:52 pm
    Sounds like you had a calibrated demo software installed:
    https://www.calibratedsoftware.com/QIMX.asp
    User guide will tell you how to uninstall:
    https://www.calibratedsoftware.com/downloads/CalibratedQ-IMX-UserGuide.pdf
    Jeremy
  • Atticus Brady
    July 18, 2010 at 8:06 pm
    Thanks Jeremy. I followed the uninstall instructions, dumping all the calibrated settings and folders from the hard drive, re-started, and while the calibrated message has disappeared from a couple of the thumbnails and it no longer appears during a trim, it remains visible in most of the thumbnails (it’s a 35-min sequence with lots of edits). Any other suggestions?
    Atticus
  • Greg Booth
    July 18, 2010 at 8:45 pm
    FCP caches thumbnails so you would need to turn off then turn back on thumbnails or clear your cache to force FCP to re-make your thumbnails.
    Cheers,
    Greg
    Calibrated Software
  • Atticus Brady
    July 18, 2010 at 10:21 pm
    Thank you for your help gentlemen. I wound up trashing the Thumbnails Cache Folder and that did the trick! Thanks again.
    Atticus
