Activity Forums Panasonic Cameras Calibrated MXF Import v1.0
  • Calibrated MXF Import v1.0
    Posted by Michael Colin on June 22, 2008 at 12:29 am
    Greetings. The Calibrated MXF Import v1.0 for OSX is pretty new, anyone had a chance to work with it on a mission-critical level? I tried the demo, seems to work fine. As advertised, the P2 MXF files imported with sync sound, no Quicktime file! Using it would allow me to scratch one hard drive from our purchase list (no-budget film), but I don’t want to be the guinea pig….
    Appreciate any feedback.
    Best,
    Michael Colin
    Jeremy Garchow replied 18 years, 3 months ago 4 Members · 3 Replies
  • Noah Kadner
    June 23, 2008 at 2:58 pm
    Hmm- that looks very promising!
    -Noah
    My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color and Win a Free Letus Extreme.
    Now featuring the Sony EX1 Guidebook and Sound for Film and TV.
    https://www.callboxlive.com
  • Michael Sacci
    June 23, 2008 at 8:40 pm
    [Michael Colin] “Using it would allow me to scratch one hard drive”
    Careful, while it would be great to by pass the transfer process I would highly recommend having the footage backed up to a 2nd HD, which the log and transfer, kind of forces you to do. Trying to save a few bucks here can really come back to bit you.
  • Jeremy Garchow
    June 24, 2008 at 3:53 pm
    Yes, I’ve used it. the only problem (and the developer is working on it) is that it won’t transfer User Clip Name metadata into FCP. Although if you open the clips in Quicktime, you will see the User Clip Name. You can also use this to open clips in other FCS apps with no transferring.
    >>EDIT Concerning addition and removal of pulldown: The original MXF File on disk isn’t modified at all – pulldown insert/removal just how the QuickTime video tracks for the MXF file are built in memory – the MXF files on disc are not written to.
    Also, pulldown removal/insertation can be turned off/on for select frame rates via the Calibrated MXF Preferences Panel
    It is very very handy for checking clips on set without have to log and transfer first.
    The FCP P2 workflow is getting there. It’s so close to allowing native MXF editing.
    Jeremy
