Activity Forums Apple Final Cut Pro Legacy Calibrate Monitors in PAL
  • Calibrate Monitors in PAL
    Posted by David Massachi on February 19, 2006 at 6:25 pm
    Can someone describe the correct way to callibrate a pro video monitor when working with PAL video?
    Is it the same as with NTSC?
    Can I use the PAL Bars and Tone in FCP5 to do this? Does the bars/tone clip need to be in my PAL Uncompressed 8-bit timeline when outputting to monitor for calibration?
    My system:
    Sony PVM-20M4U, component video input
    Dual G5 2.3GHz
    4.5 GB RAM
    OS 10.4.2
    FCP 5.0.2
    QT Pro 7.0.3
    AJA Io with Driver v2.0 and Firmware Update v23-28
    AJA ProIO Control Panel v 1.0.0
    Uncompressed 8-bit 4:2:2 to/from DVW-A500 via SDI
    massachi
    David Massachi replied 20 years, 7 months ago 2 Members · 2 Replies
  • Stuart Simpson
    February 19, 2006 at 11:29 pm
    There’s a helpful section in the FCP manual which will take you through the process for both PAL & NTSC standards.
    -Simmie
    2 G5 – Cinewave
    3 G4s – Cinewave
    1 xbox360, 1 PSP, 1 PS2 & a Gamecube
    https://www.speak.co.uk
  • David Massachi
    February 19, 2006 at 11:42 pm
    Wow, that’s simple. Thanks, Simmie.
    massachi
