Activity › Forums › Apple Final Cut Pro Legacy › Calculating TRT Non-Drop Seq to Drop master tape
  • Calculating TRT Non-Drop Seq to Drop master tape
    Posted by Michael Sacci on February 6, 2009 at 9:15 pm
    I’m laying off masters for a client and all his sequences are 1080 23.98p NonDrop frame, mastering to HDCAM 1080i 29.97 Drop Frame. No problem with the process except his TRT on the slates are not the same, program starts at 01:00;00;00 but on the first tape seq. ends 01:56:15:16 but that frame on the tape is 01:56:19;04. Is there a calc out there that can figure out the difference so we don’t have to print the tapes and then go back and change the slates?
    Michael Sacci replied 17 years, 7 months ago 3 Members · 4 Replies
  • John Pale
    February 6, 2009 at 9:38 pm
    I think he knows the overall duration, he just needs the segment times for his slate.
    Your idea will still work though, if he adds edits to the slug where his segments start (or end).
  • Michael Sacci
    February 6, 2009 at 10:01 pm
    Thanks Dave, I was kind of thinking that but I tried to nest the seq and it would not do that but we have an export of the program in one piece and when I dropped that into the 29.97 seq I got the new TRT.
  • John Fishback
    February 6, 2009 at 10:13 pm
    Shane has a link in this thread to his t/c calculator which might do the trick. https://forums.creativecow.net/thread/8/1021720#1021731
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Michael Sacci
    February 7, 2009 at 3:42 am
    I had something similar but it does not deal with pulldown but it you enter the TRT as Non drop 29.97 and change it to DF it will be within 6 frames.
