Activity Forums Maxon Cinema 4D Calculating number and size of cog teeth…
  • Calculating number and size of cog teeth…
    Posted by Trevor Gilchrist on May 3, 2013 at 7:09 pm
    Hi.
    I have to create a clock-type cog (60 teeth) that is driving a flat panel with (hopefully) matching grooves (see attached pic).
    The absolute dimensions are not particularly important, but I was hoping some math whizz out there could clue me in as to relationship of cog teeth to panel teeth? I’m faffing around doing it by eye, but there has to be a more scientific solution/formula…?
    If cog = diameter x and inner diameter y and has 60 teeth, then panel must have grooves of z width and depth.
    (spot the non-mathemetician)
    Many thanks in advance to anyone who can help.
    Trevor Gilchrist replied 13 years ago 2 Members · 2 Replies
  • Brian Jones
    May 4, 2013 at 5:13 am
    circumference = πD and the circumference is the same distance the plate needs to move to keep pace with the outside of the rotating cog so, if the panel teeth go all the way in (touch the inner diameter of the cog wheel) use the inner diameter of the cog wheel for D –
    distance the plate needs to move = π x Cog inner diameter
    there are 60 teeth so each panel tooth needs to be 1/60th of that distance apart
    assuming that’s what you mean…
  • Trevor Gilchrist
    May 5, 2013 at 2:40 pm
    That’s exactly what I needed, thank you so much.
    Inner diameter of my cog is 200
    200 x Pi gives me a 628 panel/60
    Perfect, thank you.
