Activity Forums Adobe After Effects calculating focal length of a footage with zoom
  • calculating focal length of a footage with zoom
    Posted by Petcov Petru on December 20, 2011 at 7:51 pm
    Hello I apologize if I post this in inappropriate forum but I already posted in other forums and no replies so I’ll give it a try here.
    I want to track and get the right camera solve of a shot in Boujou with large zoom which I filmed it.I tried it but I can’t get it right.
    There’s enough 3D points in the solved camera but they are positioned mostly on X and Y axis,just a few on Z axis and so in fact Boujou doesn’t reconstructing the depth of the scene.
    I tried it with automatic Assess Lens Distortion but the result is almost the same.From what I’ve found is to input the right value for the Focal Length but I don’t how to calculate it.
    I don’t know for sure the exact display resolution at which my camera shoots.All I found about this is what I saw on the box in which came the Camera and there it says Display 1024X768 but I don’t know what this represents – maybe is the display of the camera’s LCD screen – if you know please tell me.I was setting the camera to shoot in the best mode.
    The original files are MOD files and is Pal 1.09(i think).When I look at the file properties on my Windows7 it shows 720X576 and also when I import the video in After Effects it shows me the same display resolution.
    But with that width it doesn’t display the entire width of the video so I changed to Pal widescreen so now is 1050×576 PAL widescreen, 25 fps.
    The camera is Canon FS100 if that matters.I’m very beginner so I don’t know exactly what those numbers means but I can tell you that on the camera at the side of lens I see that is written 2.6-96.2 mm 1:2.0.
    So to tell you how I have shooted the video – I was standing in the midlle of the street and I made a zoom from minimum to maximum on a building which close the street(like dead end street).
    I aproximate the building beeing about 6-7 meters tall and maybe 20 meters wide.
    The camera is hendheld and has some shake,I have not moved.
    I don’t know if I have to provide more information,but anyway that is all I can tell you at least for now.If you want to ask me something just go ahead.
    So if anybody could help me I would much appreciate it.Thanks
    Petcov Petru replied 14 years, 8 months ago 3 Members · 6 Replies
  • Walter Soyka
    December 21, 2011 at 2:09 am
    If the camera is zooming, the focal length is changing during the course of the shot. You can’t input a fixed focal length.
    Walter Soyka
  • Darby Edelen
    December 21, 2011 at 8:11 am
    To add to what Walter has said: the reason you’re not getting any depth tracked on this shot is because there is no parallax.
    Panning or zooming does not change the parallax in a shot, and the parallax is the only thing that a computer can use to estimate the focal length of a lens or depth of a scene. Parallax only occurs in a shot when the camera moves
    This means you can’t really solve this shot in any 3D tracker. On the upside, you shouldn’t have to solve it in a 3D tracker because your shot doesn’t have any (much) depth. A 2D tracker that supports position, rotation and scale should work for you. Mocha AE is a popular application that works well with AE. I don’t know much about it though so you’ll have to do your own research there 🙂
    Darby Edelen
  • Petcov Petru
    December 21, 2011 at 10:15 am
    Thanks both of you but I really don’t know what to say because I saw a tutorial(it’s the 7 tutorial from the Boujou (5 in my case) Help menu – Using Focal Length Constraints,that one with the old taxi car – if you know it) and that shoot has a zoom.
    So they input 4 focal length values at 4 different frames – Indeed the zoom is not that large as mine is and there is also panning too but Boujou solved it well.
    From what I see(if i see well :)) the camera doesn’t move.
    Maybe I’m missing something,I don’t know.
  • Petcov Petru
    December 21, 2011 at 10:30 am
    I forgot to tell you.They don’t say where do they know these focal lengths values from.
    Here is a quote from the tutorial:
    “The focal length was varying throughout this shot but the value is known at four frames,including the first and the last”
    And then is a table with these 4 values.
    So how to they know these values?
  • Darby Edelen
    December 23, 2011 at 3:46 pm
    They most likely marked values on their zoom ring with tape and kept notes of these values.
    Trackers can solve for panning shots but its a different kind of solve than one with parallax and will significantly hinder the solvers ability to estimate a focal length accurately.
    Darby Edelen
  • Petcov Petru
    December 28, 2011 at 12:27 pm
    Thank you and sorry for my late reply.
    Forgive my inexperience but can you explain a little more this:
    “They most likely marked values on their zoom ring with tape and kept notes of these values.”
    because I don’t really understand how this can help me whith my problem.How can I know for example the focal length for a certain frame
    I just want to know how to calculate the focal length,at least for the first and last frame.
