Activity Forums Compression Techniques Calculating Encodes
  • Calculating Encodes
    Posted by Jaime Quintana on January 16, 2009 at 8:27 pm
    So, I was wondering if there was a widget or equation of some sort that will let me calculate how big a file will be after encoding, For instance, if I have an HD 1080i 2GB file and I wanted to encode it using motionJPEG-B, is there a way to calculate that? A widget that lets you put in the source file info and select the codec would be ideal. Does that even exist? Or am I going to have to be the one to develop it?
    Daniel Low replied 17 years, 8 months ago 2 Members · 1 Reply
