Activity Forums Compression Techniques Calculating Compression Render Times
  • Calculating Compression Render Times
    Posted by Chip Hess on November 11, 2012 at 11:48 pm
    I have been asked to bid on a huge compression project, for DL DVD.
    I can estimate file sizes using the various bitrate calculators.
    But does anyone know how one might estimate how many hours
    such a task might take, given certain computer specs?
    I’d like to bill hourly
    and give a ballpark idea of the total.
    Thoughts?
    Richard Quiner replied 13 years, 10 months ago 3 Members · 4 Replies
  • Jason Brown
    November 12, 2012 at 12:38 am
    Are u talking mpeg2 SD-DVD? Or bluray?
  • Chip Hess
    November 12, 2012 at 12:59 am
    mpeg2 SD-DVD Dual Layer
  • Jason Brown
    November 12, 2012 at 3:14 am
    nevermind then…I had an idea for h264 bluray compression.
  • Richard Quiner
    November 20, 2012 at 8:32 pm
    There are a lot of different variable with this. It will largely depend on your computer specs. if you have a good processor and plenty of ram it should be relatively quick. Also the source will affect the speed. i recently did several DVDs from an SD source and encoding the video took about 45 minute – 1 hour per 2 hours of footage. If I were you, I would just run some benchmark tests on the system you’ll be using with footage that is similar to your source to get some ball park estimates. Good Luck!
